Perform this procedure to traceroute to an IP address on Fabric IPsec Gateway Virtual Machine (VM).
  1. Enter Fabric IPsec Gateway Configuration mode:
    enable
    virtual-service WORD<1-128> console
    Type CTRL+Y to exit the console.
  2. Traceroute to an IP address:
    traceroute {A.B.C.D}
Traceroute to IP address.
Switch:1> enable
Switch:1# virtual-service figw console
Connected to domain figw
Escape character is ^Y
  <cr>
FIGW> traceroute 192.0.2.100
The following table defines parameters for the traceroute command.
Variable Value
{A.B.C.D} Specifies the IP address to initiate traceroute to.
